Alles anzeigenGood day everybody,
Now I have found time to provide you with a complete guide.
Hardware you need:
- OBD dongle to read the vehicle (e.g. OBD Link Amazon)
- USB stick
Software you need:
Then let's get started
- Take a blank USB stick (FAT32 formatted) and plug it into your vehicle's USB port. Wait about a minute and then remove it.
- Now it's time to go to your home PC. Make sure you have Java Runtime installed.
- First you have to open the program WLSDecrypt
- On the USB stick, you should have a folder called "R-LINK." This contains a *.wls file. Drag this file to your desktop.
- Enter the chassis number in "WLS Decrypt" at the top and click "Decrypt WLS." A new window will open. There, select the file you copied to your desktop.
- Two new files have now been created on your desktop. They are called "....main.json" and "...._nav.xml." Leave "WLS Decrypt" open.
- Open the "....main.json" with Notepad
- Search for "com.renault.rsmonitor" If you do not find this entry, you must enter it manually
- Simply save the file in the same format.
- Now go back to "WLS Decrypt." If you left it open, the chassis number will still be there. Otherwise, enter it again.
- Now click on "Crypt WLS" in the program. You'll be asked for the two files you have on your desktop, one after the other.
- If everything worked, the program will notify you that it was successful. You'll then have a ".wls" file on your desktop. Copy this file to the R-Link folder on your USB stick. You can delete the other "*.wls" file.
- Next, open the R-Link Toolbox. Wait a moment, and you should see the following:
- Install the RS Monitor on the stick.
- Now you can plug the stick back into the vehicle. Wait a moment and the RS Monitor will be installed.
- Now you have to tell the R-Link which vehicle it is.
- To do this, connect "DDT4ALL" to your vehicle and go to the following tab:
And the RS Monitor is finished. For now, I only have the performance curves for the TCe 160 and the GT 205. I'll take a look at finishing the performance curves for the other engines and submit them later. But only with your request. So, if anyone needs a curve for a different engine, just write to me and I'll get it ready as soon as possible.
Code for the TCe 160:
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
Code for the GT 205:
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
If you have any further questions, I'm happy to help.
Until then, have fun trying it out.
Good afternoon everyone,
I am so happy to join this forum for our Megane.
I recently bought a Renault Megane IV GT and I want to install RS Monitor on it.
Nanny Congratulations for your tutorial and keep going with this nice job!
Your instructions are very nice and clear, but I cannot download WLSDecrypt from your link, because it is no longer available. Can you please provide it to me in any other way (either to upload it somewhere and share with me a download link or send ir to me directly by an email, etc)?
Thanks in advance!
