Clutch noise while gearshift
  • Hello everyone,
    I'm coming back to you asking again for your favor.
    I'm owner of Megáne 4 2016 with 1.6dci 130 engine, 170 000km.
    Last two-three months I'm experiencing this (Youtube link) weird noise while pushing the clutch pedal. It's like coming from under the dashboard. It first occurred during gear change at higher speeds - from 4 to 5 and to 6. Now it's basically from any gear. Doesn't matter if the engine is loaded or not, meaning with releasing acceleration pedal immediately before gear change.
    But the car has to be moving. When it's stationary nothing occurs. So with engine off no noise again. I tried to lubricate the pedal joints and everything which is actually moving around in interior with no change.
    Has anyone from you experienced the same or have any suggestions what could be the root cause?
    The noise starts to be quite annoying and also not sure how it can end up, car to stop, gearbox damage etc.
    Thank you in advance
  • Hey otichac,
    Wenn das Geräusch im Stand nicht auftritt, kann es wohl vermutlich nur am Zweimassenschwungrad liegen.
    If the noise does not occur when stationary, it can probably only be caused by the dual-mass flywheel (DMF).
